Hi everyone,
Had this exhaust sitting around for a long time and tried to install yesterday. Getting the bolts to even line up enough to get started was tough and once I manage to get them in the exhaust sits rotated counterclockwise. I tried tweaking the mounting tabs just a little in a vise and even the right side one on the frame just a little but it is still pretty far off. Only found one thread similar and just mentioned to work with the mounting tabs. Anybody else experience this? It’s not really that close, I’m pretty surprised. Thanks in advance
34480
You need the spacers for the exhaust to straighten it out..
Thanks. Do you mean the brass inserts that go through the rubber grommets? I have the small one on the left rear and thicker one on the right front one but still tilted. I’ll try again. Thanks
This is what it should look like.
34481
