I just replaced the clutch basket with OEM, and put in new hinson plates, fibers, and springs. Followed everything to spec putting it back together, but now it won't stay running in neutral. Starts up fine cold and idles normal, then gets warm and dies. Starts back up and dies after a second or two. Didn't do this before I did the clutch work. Soaked the fibers, running Rotella t4.
I'm lost, anyone have an idea where to start?
For references, do you installed the special rings and plates as pictured ? ( 9 - 10 - A - B ). Because, normally the clutch, even fully engaged or disengaged will not restrict the engine from turning exept if something is not installed the right way.
34530
34531
