i have a 06 ltr 450 i bought that needed a new head so i replaced it and cant get it to run unless i unplug the fuel pump if it is plugged in it only sparks 3 times then stops when you hit the start button i have check the stator, pick up, wiring harness and injector ive also have swapped out tps, fuel pump, ecu, tip over sensor and relays and have checked everything twice really lost on what it could be
2006 Ltr450
Keyswitches have been known to go bad cause weird stuff, but think it would blow a fuse, study the wiring diagram closely , ltr electical problems are rarely easy
