I dont know if I will get in trouble for linking to another site but here goes.
http://www.atvtech.net/forums/index.php?showtopic=1241
wonder what the specs are on those.i installed the yosh intake cam on mine and noticed a pretty good increase.at the track i normally practice on when my quad was stock i would hav to click 4th gear and pin it to clear he top to clear this step up tripple it has.when i did the cp piston porting airbox mods i could do the jump in third pinned and clear the top about a quadlength.after i added the intake cam i could clear it in third tapped by about 2 -2.5 quad lengths.im thinking that is more than one hp.i will have to try to get the specs and compareYeah after getting rid of the restrictive airbox and putting on a PIM module, I noticed the cams aren't as bad as I had originally thought. I was sure they were signing off really soon. It turned out that the airbox was causing the motor to just sign off. A good breathing setup with a good box(PIM) is pleasing me for now.![]()
Click me
If you can properly tune the computer to work with the cam it would gain alot more, unfortunetely there aren't many good tuning programs for the ltr450 yet, other than a few programmers..wonder what the specs are on those.i installed the yosh intake cam on mine and noticed a pretty good increase.at the track i normally practice on when my quad was stock i would hav to click 4th gear and pin it to clear he top to clear this step up tripple it has.when i did the cp piston porting airbox mods i could do the jump in third pinned and clear the top about a quadlength.after i added the intake cam i could clear it in third tapped by about 2 -2.5 quad lengths.im thinking that is more than one hp.i will have to try to get the specs and compare
