So I just put new piston and rings valves and springs in my 08 ltr last night. After I put the motor together I put some oil in it and did a compression test. The test was at 120 psi and the engine had no problem turning over. This morning i finished putting it all back together but when i went to start it it will hardly turn over and is acting almost like the battery is dead. Getting ready now to tear it down again and look for something I did wrong any suggestions?
Check the torque on your cam caps! Also cranking compression above 110-115 will cause issues. Do some research on heating and bending the decompression mechanism if you don’t find anything out of place elsewhere.
did you end up figuring out your issue?
