1 - 20 of 31 Posts
Alright, when it comes to wiring, I am kind of a WALLY. Looking at the wiring diagram(thanks Junkie) there are 3 wires coming from the headlight. Yellow=High beam, White=Low beam, and Black/Yellow which goes to the clutch switch. When wiring up the lights, you wire one wire from the TT light to either the Yellow or White, depending on what you want your lights to come on as, low or high setting. You take the other wire and wire it to a ground wire. Here is my question: I am going to wire one to the Yellow, tape up the White, and wire the the other wire to the Black/Yellow. Will the Black/Yellow wire serve as the ground wire or am I misinterpreting the directions. Anybody got any info. Thanks in advance. :unsure:
Discussion Starter · #2 ·
Surely not all of you are as dumb as me? :smiley_1poke:
Thank you very much sir. I'll see if I can't blow this thing up :blowingup: , when I get home from work tonight.
I have the trail tech HID. Thats how I wired them. seems to work fine.
Yellow power
black ground.
with the trail tech lights there is no hi/low beam option???
No there is not...You wire them to either the high beam wire or the low beam wire from your ltr.
Yep. Last night. No KABOOM.
Discussion Starter · #10 ·
They mount with the top shock bolt. I really wanted the frame mounted ones, but where I wanted to mount them, it wouldn't work with the bumper. I just went with the MR16's. Wanted the HID's, but I couldn't see spending over 3 bills for them. I like the way they turned out.
did you get the 35w or 50w halogens ?
Discussion Starter · #13 ·
I have both actually. I have the 35w in now.
very cool. so if you wanted to you can just use the key to turn the lights on and off and with a starter button you could get rid of the original combination switch. thank you.
Discussion Starter · #16 ·
can you post a pic of your setup Kracker? thanks
Yes, but it will be late tonight, or tomorrow.
Discussion Starter · #17 ·
Sorry it took so long. Been busy. Here you go. Not quite tightend and aligned, but you get the idea.
Discussion Starter · #19 ·
Thanks Pokrmny! :p
1 - 20 of 31 Posts
