It's better to use the stock filter as it is designed to filter water out of the fuel. Periodically check the bowl though. If water is left in the bowl, it tends to start corroding the bottom on the inside, causing the filter to clog. Just some info I have found during my time with the bike I have.
Discussion Starter · #10 ·
You are correct. This is how they were meant to work
