1 - 20 of 21 Posts
Can anyone break down exactly what preload, compression and rebound are? Or point me to a web site or forum that will explain it and the proper adjustment procedures? I am 5'9" 150 lbs and my LTR seems very stiff! I need to soften it up quite a bit and have no clue what I am doing. :huh:
Thanks.
Thats definitely a start. The users manual gives some info also so I am gonna play with it this weekend. Another rider suggested turning all the settings down as soft as possible and adjusting up in stiffness until I find the sweet spot. With my featherweight build I am hoping it will get soft enough. We'll see.
Thanks for the input. :D
i weigh about the same as you. i turned the preload all the way down and turned the compression down two turns. i rode it a bunch and after awhile the front softened up a lot. now it's perfect.
I am glad to hear that. Then it is definitely just a matter of adjustment.
Rin...good find there bro...saved me from ordering a back issue :D
The quick way i tune my rear suspension:
Slow compression: All the way out, SOFT
Fast compression: All the way in, HARD
Rebound: Adjusted so when i violently jump down on the quad it doesnt buck up from the rebound, but it is fast enough so it does it *quikly*
For the front it is pretty close to the rear, but i just give the slow compression a couple turns in, harder.
Discussion Starter · #12 ·
Nice RinTin! Thanks. That, along with everyone else's tips and suggestions is exactly what I was looking for.
Thank you! :) And everyone else too who took their time to reply.
I'm already a poster child for a propholactic ad campaign... :(
I WANT MY CHROME!!!!!
:p
SHHHH Junkie now take your pills.
I didnt want to use up brandwith so I thought I could throw my question in here.. Does anyone know how I can simply get to my rear shock preload and compression? what I do and dont have to take off? Thanks a lot guys... I just tuned my suspension yesterday and its 100% better.. I tightened up my preload before I understood all the tech stuff and it was all wrong.. my ride height was wayyy offf too high :D Thanks in advance guys
1 - 20 of 21 Posts
