there's no need to remove the chain to change sprockets on just about every atv/mc..... :blink:There's no master link in the stock chain.
What technique are you guys using to remove the stock chain in order to swap from sprockets?
You have to take the chain off the sprocket to remove the sprocket - c'mon man. :huh:there's no need to remove the chain to change sprockets on just about every atv/mc..... :blink:
no, you don't. as long as you loosen the rear bearing carrier mount and get a good amount of slack in the chain the front sprocket will slide right off then just take it off the chain. Or you could always take the rear sprocket bolts out and you'll be able to take the chain off the rear and front sprockets. the only time you'll ever need to break the chain is to remove it for a new one. :cheers:You have to take the chain off the sprocket to remove the sprocket - c'mon man. :huh:
To everyone else, thanks!
