81 - 100 of 130 Posts
I have a 06 450 with yoshi exhaust and cherry bomb. To get it to start i have to hold the throttle about half way down and it still takes a good 20 seconds to start but if i roll start it with the throttle half way it fires right up. Any help would be greatly appriciated.
thanks
same problem here any help
Could be your valves out of spec
I need to find a new map for my power commander. I just removed the trinity exhaust and the fuelatv intake. its running only the 12.8:1 piston now with a 110/92 fuel mix. Cant get it to idle right with the current map or with the PCIII unplugged. on start up the throttle sticks at a pretty high rpm, rev few times goes down. if i touch the throttle it bogs and dies.
fast idle lever
i have an '08 LTR thats having trouble starting , i have to use three hands to get it going. it seems that the fast idle cable has stretched out. i have to hold down the fast idle lever with force, push the start button and give it 1/4 throttle to get it to fire up. then it wont idle till its nice and warmed up, if i dont use the fast idle it takes 20-30 seconds for it to even fire and then its hit and miss if it'll stay running. i was thinking of removing the fast idle and using the (yosh) block off plug ? the fast idle lever seems slack like theres no resistance pushing it thru its range of motion ....
also was thinking about going to a stage one cam set .... yes/no ?
looking for a steering stem, stock or aftermarket +2 w/ 1 1/8 clamp
i got a new fuel pump and had my injector tested and its still wont start with out starting fulid and i took the swirl filter out
no It's not,, it's in my sig, lol
ok i have a 06 ltr that i was having trouble starting, some times it was fine and other times it would do a half a turn and stop like the battery was dead. i rod it in to the shed then put it away and the next time i went to start it the motor just turns ove freely like it has no compresson. wont even start with starting fluid what could thid be?
Ok have read thru here don't see answer. I have a 06 yosh stage 3 with pipe cherry bomb exc. Have a hard time getting it started, have to give it about 1/2 throttle and will finally start. When it is warm will start easier but still have problems. The motor has 15 hours since full rebuild. Any thoughts?
I have a starting issue, I am less than 5 hours from a full rebuild, and the mechanic told it was the compression relese? I was wondering how to test it? It will start and run fine but when hot, if i kill it it wont crank fast enough to restart and when cold it cranks slow but starts
