I have seen a couple of guys with starting issues -- let's try to use this thread.
I went out this weekend for my second ride. After my first break -- tried to start -- NOTHING.
Battery power - yes -- BUT No starter turning. I checked the fuse... thought about the roll-over switch.
I found my problem. The relay on the clutch perch was loose -- doesn't seem to be making a good connection. It is used to keep the starter from engaging without the clutch lever pulled in. I am going to remove mine. If you trace the wire back down to just in front of the handlebar mount, there is a clip/plug.
I am going to cut just below - splice the wires togehter -- eliminating the need for a relay.
Keep in mind if you do this. The starter WILL engage without the clutch pulled in -- jerk you froward.
So use the clutch or put it in N.
Hope this helps some of you other guys.
Stacy
Stacy
