1 - 20 of 27 Posts
I tried removing my spark plug the other day but it seized up and when I turned it it just snapped. The only part left is the threaded part of the spark plug so I cannot grab it with pliers.
I removed the head and I have lubed it as much as I could and tried to turn it with a flat head screwdriver and a hammer but it will not move, instead the screwdriver just digs in into the plug.
Any help would be greatly appreciated. Thanks.
I can post a pic if it helps.
That can be a tricky problem to fix. I would recommend shipping it out for removal.
I can repair it for $25 if it doesnt need a helicoil and $35 if it does.
Sorry but I don't live in the U.S. and shipping it would mean 3-4 weeks with no running engine but thanks for the offer.
Would you be able to tell me what size helicoil I would need to do it myself?
I have tried heating up the head but it's just stuck in there. I'm pretty sure an ez out would just snap.
Couldnt you remove it by drilling and tapping?
Drill it out, start with a small bit and work your way up to a larger bit, don't worry if you don't get it centered, just drill until one side is almost through to the threads then pry the 2 sides inward and then you should be able to unthread the rest or break the spark plug leftovers in half, i've done it with broken bolts before just never with a spark plug, then chase the threads with a tap.
Discussion Starter #6
I'm going to try onesavage's method and if it doesn't work then I'll helicoil it. Thanks for the help guys.
Discussion Starter #7
I haven't tried drilling it yet but I was at the hardware store and saw an expensive, German made ez out kit, so I bought it and gave it a try. It didn't work, the plug is awfully sized up in there. Drilling is next.
LoL, thats what I was talking about. They can be a real pain. Step drilling is your best option, but do it with some quality bits. The final tap size is a 10mm x 1.00
I had this happen already... but in my car... pain in the freakin ass... but as for ltr... everytime i pull the boot off the spark plugs it rips...
did ya get it fixed?
Discussion Starter #13
We don't get any pb blaster here unfortunately.
I haven't gotten it fixed yet, I thought I had the right size bit to drill it but I don't so I gotta go out to buy some. Also I just called Suzuki and they said they could fix it for me for about $15 so I might just take it to them.
take it to them, that way if they break it, they buy it. you already spent enough time and money running around..
Discussion Starter #15
I took it to Suzuki and when I got there they said, oh no, sorry we can't fix this, we thought there would be some of the plug still sticking out. So I wasted 30 minutes in traffic.
So I'm gonna take it to a good machine shop I know, they should be able to do it. If not I'll be drilling.
effers... that sucks, sorry bro...
Discussion Starter #17
What to do... What to do...
Discussion Starter #18
Went to the machine shop, they didn't want to do it so they recommended me another machine shop. I get there and they tell me they need a spark plug to remove it. Why, I don't know, to check the thread or something maybe? I didn't have one so I go back home and get my spare ones, I can't find them anywhere so I go out and buy another one. I get back to the shop and they tell me to bring it back on Monday. I got p'o because I spent an hour to get a damn spark plug when I had things to do and then they tell me to go back a different day when they had already told me to get the spark plug and come back. So I got my head and left. I went to about 3 other shops and no one wanted to do it.
So I said screw it, I'll do it myself. I drilled it but I still couldn't get it out. So I went to get a helicoil kit but they don't have the right size kit or the right pitch helicoil and this is after going to 7 shops.
So I think I will have to order one from ebay but I want to make sure this is the right one.
10x1 mm Heli coil spark plug thread repair NGK C Type | eBay
Discussion Starter #19
OR.... I found a 10x1.5 helicoil kit here so I could have it fixed by tomorrow instead of waiting 1-2 weeks for international shipping. What if I just get a spark plug with a 1.5 thread pitch? Are they hard to come by or would I be better off ordering the 10x1 kit?
1 - 20 of 27 Posts
