I am installing a RPM twin row bearing carrier but noticed that there are 2 additional o-ring(?) outer grooves toward the center of the carrier. Does anyone know if additional o-rings should be installed in those grooves? That would make it 4 o-rings then(stock only has 2 o-rings).
Thanks in advance.
Discussion Starter #2
Finally got in touch with RPM. I was told to only use the 2 outer grooves for the o-rings like the stock carrier.
