what is every problem that the new 450 is haveing that they need to fix?
I HAVE HAD ZERO PROBLEMS WITH THE 450. ITS A KICK ASS MACHINEwhat is every problem that the new 450 is haveing that they need to fix?
Classic......One for the ages.My heifer nut fell off the bull pin shaft. Luckily, its under warranty. Dealers secretary hooked it right back up.
Ill second number 3. If I've been riding and then shut it off for some reason of stall it, it just doesnt want to start back up, especially if that fan is on. It doesnt have quite enought power to use the fan and electric starter. This only happens sometimes.Here is a list of the problems I have had with mine.
1. The tip over sensor under the front plastics.
2.Weak spot in rear of frame that had to be re-welded.
3.Has problem starting when it is hot.
4.Most recently, it's been losing its power in the air only. Something with the fuel injectors.
5.Air filter ripping
6.Yosh exhaust blew two rivets out of the side of it
