I have an oil leak coming from a wire housing/gasket on the left side of the engine, near the case saver. I need help identifying the wires or housing (whatever its called) so I can buy a replacement to fix it. I have a service manual but I don't know where this part is at to even figure out what it's called. Also wanted to ask if anyone has had this problem. The metal tool is point to where I am referring.
Thanks, Oz
34492
Discussion Starter · #2 ·
I figured it out. It's the grommet for the wiring to the generator. Grommet just got old and lost its sealing strength. I pulled off the cover and resealed the gasket and grommet after cleaning all the oil off. Works just fine now non leaks!
