thanks for the add! got a 08 that wasn't returning oil to the tank pulled it apart and the inner gear on the clutch side was in backwards now I went ahead and pulled the entire pump out from stator side and clutch side to inspect it....just want to make sure what way they all go before installing....the little dots on the gears do they all face the clutch side? pictures I uploaded are of the stator side pump (1st picture) and the clutch side pump (2nd picture) there should really be a sticky or a how to video on this
Yup you have it correct. Should also buy a manual. And if your ever on Facebook there’s a site on there, same name but not at all attached to this site. Ppl on there reply to you. And there’s a free manual upload you can look at if your in need of help.
