My bike recently starting bogging under hard throttle so i thought it must be a dirty swirl filter ! i took the swirl filter out and it was really dirty so replaced it emptied all the tank of the old fuel and checked the fuel pump filter which was fine . Put everything back together and it started for like 10 seconds then died and now wont start again ??
fuel pump is circulating, battery is good and fuel is getting to the pump .
probably got some dirt in the injector screen or fuel pressure regulator since you were messing with lines and had them disconnected
i didnt check the injector but the fuel pump filter was really clean so guessed the injector must be fine , i dont think it can dirt in the lines i cleaned it all out . i think its the same problem as before i changed the swirl filter to a clean one ?
