I have replaced the fuel pump because I was not getting fuel at the fuel injector. I am also not getting voltage at the connector, any thing I can test or check?
I actually fixed it it turns out that it was the swirl filter was completely clogged almost which probably made the fuel pump go bad what I didn't know was the fuel injector does not get a voltage pulse unless it's getting 47 lb approximately of fuel.I have replaced the fuel pump because I was not getting fuel at the fuel injector. I am also not getting voltage at the connector, any thing I can test or check?
