Hello new to the forum and the LTR. Just picked up this quad but the current map is not correct it breaks up at WOT. My mods are:
Full Yoshi RS5 Exhaust with quiet core in!
Cams
Aluminum air box (not sure make) with UNI filter No lid
13.1 Piston
The quad came with these mods but I have tried some of the maps from Yoshi and it still doesn't run right. Any help would be greatly appreciated.
Before you go messing with the map to much I would check your fuel filter under the tank and the small screen filter in the fuel pump as mine starts cutting out at wide open. Make sure all of those are good before you get dynoed or get your map dialed in as it will never be right if you don't. It could be the map but those filters are notorious for causing those issues.
Thanks I will check both the fuel filter and screen weekend.
