i have a motoworks slip on, factory valves, some mild porting, k&n filter with billet adapter, 474 piston, and cherry bomb. i cannot find a map that i am really happy with, does anyone have one that can help??? i don't mind plugging in values myself into my map. i run at sea level, or really close to it. i have a pcIII. Thank you!!!
Are u not close to a dyno?
i found out mid build that i needed a new piston and either a new sleeve or jug, and i opted to go up in bore, which tipped me out of range for a cherry bomb, so then i had to buy a programmer, and i thought i would be able to find a map fairly simply, then i found out they didn't have one premade. the extra $$$ i had to spend on the cylinder and power commander has really put a big dent in my wallet. i took a look at big robs low elevation map, and that seems decent, but it still isn't exactly what i have so i worry a little.
