Certainly. You can start by removing the airbox lid, the baffle (peashooter) from the exhaust and adding a CRBM module. That is really cheap. Then if you need more, you can add a good flowing full exhaust system. If you still need more, you can add an Intake cam, followed by head porting, higher compression piston and finally a bigbore kit. Hope this helps.
then if you still want more power you can throw a bottle on there and juice it
