1 - 5 of 5 Posts
A little help needed. I put in a BCS bracket due to the shift pin boss braking (engine case). When I put the bracket in I lose shift motion up or down and will not shift through the gears. If I take the bracket out and move the gearshift lever I have full motion. I have the gearshift shaft gear centered with the gearshift cam driven gear. I had it all together and I could not shift into neutral. (hind sight is 20/20). What am I doing wrong??? Mayday
did you put the cir-clip back on the shift shaft on the shifter side? something to check for.
Is this an 08/09 model quad that you have?
1 - 5 of 5 Posts
