Correct and it is not directionalSo tie the two wires together with the resistor. Does it matter which direction the resistor is going
Sent from my iPhone using Tapatalk
I did bothCorrect and it is not directionalSo tie the two wires together with the resistor. Does it matter which direction the resistor is going
Did you heat shrink the resistor wires or tape them up
you still have the harnessput the wire in both sides of the injector plug, one side of the plug is power from the fuel pump relay and the other side of the plug goes to the ecu.
if you buy my harness it already has the resistor on itLOL
