Purchased an 06 LTR450 about 2 weeks ago. Got a fairly good deal on it considering it came with all 4 paddles, quad has air box kit, yoshi pipe, power commander 3, fresh trans rebuild, etc. bought it from the original owner! Anyways, the quad starts right up no problem but it will not idle. It runs and rides just fine! No popping, sputtering, bogging etc. I checked valves they were in spec. Drained out fuel put fresh gas in. I’m stuck and don’t want to work on it anymore and throw money at it for I’m sure it’s something very simple! And yes, I messed with the idle screw... it did nothing. It WILL idle on the choke though!! any help is appreciated
It may be as simple as charging your battery. I had the same problem and realized the battery was low. And if its not that its something to do with fuel.
