was riding then died wont start not getting fire just cranks in cranks I've tested coil the proper oems are going to it and the stator got swirl filter delete stage 2 cam,cherrybomb,procom blackrev ecu,Yoshimira exhaust. I've can't get it to fire not even with starting fluid she won't start im lost fir clues
did you do a compression check?
Did you check to see if you have spark?
Did you check valves?
