41 - 60 of 70 Posts
AN ABSOLUTE BONE STOCK, MEANING UNTOUCHED MOTOR/SPROCKET/TIRES will go go between 70-75MPH. Only reasons why the quads MPH will alter will be climate/altitude and if its a manufacture rocket. This quad wont go anything over 75MPH stock. Pipes/Cherry Bombs/Tuners/Airboxes/Airfilters will do ABSOLUTELY NOTHING FOR MPH. Those mods only lower ETS, but will not increase MPH. Gearing will only alter the mph.
  • Like
Reactions: JustARaptorguy
I must have a rocket then or maybe its because I'm in Louisiana
"cshort07", I can't wait to hear your response. How fast does your ltr go?
I'm going to try putting video on YouTube tomorrow.I called the guy I bought it from today just to check if he did change sprockets or gearing and he said it was totally stock.Anybody who thinks I'm full of sh!! Is welcome to come to Clayton,La and test it.
around 122 max speed if you throw it out a airplane its called terminal velocity:rolleyes1: add 4 mph for cut fenders less drag therefor increasing the speed.
i am not the one thats going to end the thread but my 2 cents. i have a 06 ltr, when it was stock off the showroom floor it couldn't beat my 03 z400 piped 71.8 the fastest thats ever gone, after i removed the sparky and cherry bomb it was a different bike, i have since change the front sprocket 14t and put on a full yoshi and pim, gps 81.7 is the fastest i seen. i live in south florida so no elevation issues.
Well mine is not running at all now! I was wide open and it just quit like I turned tha key off. Now I can push it in gear.it has no compression at all!! I need help what's tha problem???
are you joking?????
GPS on my basically stock bike it did 72 or 73 if i remember correct....
maybe not yours. lol. it was an '06 tacoma with stock tires and no lift. speedo is correct.
no factory speedo is 100% correct. they usually read faster than what you are going.
Stock motor, gearing, and tires running race gas 112 octane.
Why would you be running 112 race gas with a stock motor????????????????????????????
race gas on a stock motor doesnt make your quad faster, waste of money.
with 13t/37t sprockets 20" rear tire pegged 5th at 73mph on a gps unit on asphalt.
Octane rating does not relate to the energy content of the fuel. It is only a measure of the fuel's tendency to burn in a controlled manner. The higher octane ratings correlate to higher activation energies. Activation energy is the amount of energy necessary to start a chemical reaction or in laymen’s terms cause fuel to explode. Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause auto ignition also called detonation. Fuels with higher octane ratings are used in more powerful/higher compression engines because an uncontrolled ignition is not desired in a spark ignition engine. You use high octane fuel in high compression engines (around 12:1) to prevent detonation, unwanted ignition of the fuel, not to produce more power. A higher octane fuel does not add more hydrocarbon content or oxygen so the engine cannot produce more power, but if the engine is under high heat or load you increase the chances of detonation. You can produce more power per BTU of energy because the fuel is only going to ignite when it receives a spark from the spark plug also known at TIMING. Also with low octane pump gas you have ethanol blending, which has less power potential then conventional gasoline (anywhere from 12% to 25% less) and the use of 10% ethanol gasoline blend is mandated in most U.S. states and cities. So now that you understand what octane is and the benefits higher high octane/race fuel can play in a engine let’s get back to your question. Why race fuel? Say you buy gas at a gas station. Most gas stations only have two tanks for their unleaded gas sales, one low octane and one high octane, (even those offering 3 or 4 octane levels). The different octane ratings are achieved by blending the two tanks before it comes out of the nozzle, area for error #1. Octane ratings are plus or minus 2%, almost 2 octane points, that’s the difference between mid grade (89) and high grade (91), area for error #2. Also in almost all states there are no state or federal agencies that regulate octane ratings at the pump, only gallons pumped, area for error #3. Octane ratings are only going to be checked at the gas refinery. So in a engine that’s at 11.7:1 compression and going of oem recommendations that you should only run 91 octane or higher ask yourself why would you risk the damaging effects of detonation, the potential for power loss, and having a ethanol blended fuel? You can if you want but I’m not going to. I live in a town where my options for fuel are very limited. Only one place sale race gas and they only sale 112 octane, and because of the elevation I live at I can only get 91 octane out of the pumps at the gas stations. I agree running 112 octane fuel is a waste, around 100 would be better but it’s not available. And yes I could have blended the race fuel with pump gas but I didn't want to go to the gas station so I ran what I had. So your right and wrong, 112 octane is a waste but higher then recommended octane fuel on a stock engine will help the engine produce the most power possible under the right conditions such as a top speed test with the engine pegged out for a extended period of time, so yes race gas can make your quad faster.......
:shocked:
where did you cut and past this info from? plagiarism can lead to a civil suit. anyways put your atv or a completely stock atv on a dyno with 91 octane and do a few pulls, then drain and flush all the 91 octane and put 112 octane and dyno the atv, let us know how much a hp you picked up. after that, do the same thing to the same bike a do a top speed run and see how many mph you pick up by switching over to 112 octane. unless you have a built motor that is set up to run high octane, race gas is a waste of money. if you have a built motor that runs race fuels, then race gas WILL make more power for your atv but not necessarily make it "faster", this post is about top speed, that is ultimately base on your gear ratio. also, why would you peg your engine out for extended period of time for a top speed run? once you peg 5th gear, it doesnt matter how long you hold the throttle for, the atv is not going to go any faster.
the ltr is recommended to run 90 octane, its on a stick that is next to the gas cap, so 91/93 premium fuels at the pump are more than enough. also, most sport bike today have a c/r of around 13:1 and still run 91 octane. so you can run pump gas at high compression ratios.
guess were all gonna have to go to Bonneville salt to settle this one...
Stock ltr top speed
I have a stock motored 06 ltr with bolt ons. geared for 1/8th mile 14/36 79.77 and 1/4 mile gearing 15/35 84.16 mph. I still hit 74.39 in the 1/8th with the 15/35 gearing, i only gained an extra 10 mph from half track to finish line shifted into 5th at 1/8th mile.
what is the stock rev for a ltr 450 ? i am sorry to say but my bike only has a 15 front sprocket and stock rear sprocket with a cherry bomb chip and a k&n air filter and i clocked out at 90 mph .... once i hit rev limiter it went down to 85 and climbing bak to 90 ...
10.5k rpm
i have an 08 ltr450 with cherrybomb no lid and uni filter going down a dirt road pinned it hit 73mph using a speedometer on my iphone which is dead on so u people saying ur quad goes over 80 are not using a good source to get there top speed
How can u say that??? U can easily hit 80 with the right gearing.
How can u say that??? U can easily hit 80 with the right gearing.[/QUOTE]
Mine has stock gearing which for a 08 is 14/37 if u went 15/35:shocked: prolly like 83 but it would be a dog on bottom end and hp doesnt add speed rpms add speed thats why without a cherrybomb a ltr450 wont go over 70
Mine has stock gearing which for a 08 is 14/37 if u went 15/35:shocked: prolly like 83 but it would be a dog on bottom end and hp doesnt add speed rpms add speed thats why without a cherrybomb a ltr450 wont go over 70[/QUOTE]
Ok...i didnt know thats this convo was about how fast u can get ur ltr to go without a cherry bomb???? U said an ltr wont go 90. With the right gearing it will.
41 - 60 of 70 Posts
