1 - 5 of 5 Posts
So.. i have brought this ltr in multiple times to numerous shops. The machine runs very nice when i first start her up during the day. But after about 5 mins of it running. Ill shut it off and it wont again.
It will turn over but will not fire. The mechanics have replaced the stator, the starter, threw in a new ecu, replaced the wires, tightend up the starter relay, put new spark plug in, put a new ground wire in, and put a new battery in it.
Have no idea what else it could be. I personally cleaned out the fuel tubes because i thought that could have been the problem and also fixed the idle on it.
Any ideas for the hard to start when hot?
Check valve lash, valves grow under heat and don't seal all the way,, especially the exhaust.
in the manual,
I know when I first bought my ltr it would always be hard as hell to start when hot and it turned out the idiot I bought it from out the shims in backwards so technically it was blown.. not sure if this helps
1 - 5 of 5 Posts
