Hello,
I have in my possession a 2006 Suzuki LT-R 450.
I end up with an injection problem:
The voltage (12v) that actuates the injector is at 12v but the problem is that once the connector plugged into the injector voltage (12v) disappears and does not exceed 1.5V. I think that the CDI must make calculations and put security.
Simple question: What prevents the injector from having the voltage going on once the connector plugs in?
Could you give me some advice or values ​​to control to solve this problem?
Thanking you
cordially
Could be a shorted injector to ground or a voltage drop across the supply circuit to the injector. You could use a Power Probe to power the 12v circuit and connect the negative terminal to ground. The circuit breaker will "pop" if shorted.
