1 - 1 of 1 Posts
Sponsors
Racing or seeking an adrenaline rush on rough terrain is dangerous, so you’d better try and find the best protective gear that meets your needs. Take a look at Leatt offerings. The company did a great job redesigning and updating older models to make their products lighter, stronger, and overall better. For example, the new Leatt 8.5 V21.1 Off-Road Helmet now comes with matching goggles, it received improved ventilation, wider eye-port, and a more comfortable liner.
To prevent neck injuries, take a look at neck braces by Leatt. The GPX 5.5 model is made of poly Aramid and fiberglass, which makes it strong but lightweight. It is designed to be placed into special slots in back and chest protectors. It has 3 points of adjustability, including the angle. The 3DF AirFit Body Protector is perfect for hot summer day trail riding. It offers CE-certified back, chest, shoulder, and elbow impact protection.
Leatt® - Moto 8.5 V21.1 Off-Road Helmet with Goggles
Features:
• Composite shell in three sizes
• 360° Turbine Technology
• Reduces up to 30% of head impact at concussion level
• Reduces up to 40% of rotational acceleration to head and brain
• Reduced outer shell volume
• A 10% smaller shell, transfers up to 20% less rotational forces to the neck, head, and brain
• Multi-density, V-shaped impact foam molded directly to the outer shell significantly reduces G-forces transferred to the head and brain
• Dri-Lex® moisture-wicking, breathable, anti-odor, and washable inner liner
• Optimal neck brace compatibility
• Maximized ventilation optimized for off-road racing and effective even at very low speeds
• Visor with breakaway function for rotational reduction in a crash
• Emergency cheek pad removal
• Hydration ready (with optional hands-free kit)
• 5.5 Motocross Goggles included
Leatt® - GPX 5.5 Neck Brace
Features:
• Independently tested and proven to reduce neck forces
• Up to 47% reduction of risk for a serious neck injury
• Rigid, non-flexible polyamide reinforced EPS platform for lowest possible neck forces
• CoreFlex split rear thoracic strut is more comfortable and designed to work with the body's natural movements
• Thoracic rear strut is engineered to snap off before applying excessive pressure to the back
• Optimal helmet rim striking platform design for a biomedical balanced head and helmet freedom of motion
• Adjustable rear thoracic strut to fit most body shapes
• Sculptured, split front for improved comfort and fit
• Engineered collarbone cut-out to help keep your helmet and brace away from your most fragile bones
• Air flow ribbed body padding for optimum ventilation
• Free, optional clear chest strap included
• CE tested and certified as Personal Protective Equipment 89/686/EEC
• Weight 497g (1.1lbs)
Leatt® - 3DF AirFit Body Protector
Features:
• Total Leatt® protection score of 21 points
• 3DF AirFit ventilated soft impact foam
• CE tested and certified as impact protection
• Chest prEN1621-3 Level 2
• Back EN1621-2 Level 2
• Elbow and Shoulder EN1621-1
• FFM-French Federation Certified
• New longer back protector
• More comfortable and flexible
• Extra upper-chest impact protection layer for non-neck brace users
• Anti-odor MoistureCool and AirMesh wicking fabrics (uses zinc pyrithion)
• Elastic chest strap to give more secure protector positioning
• Leatt 3D design ensures a great fit that is very comfortable
• Easy-to-wear, zip-up compression sock design for maximum evaporation
• BraceOn™ neck brace fitting system
• Easy to clean hand wash
• Weight 1.450g
• Unisex fit S/M-XXL (160-196cm)
Click the image for more information
To browse the full catalog of Leatt products, please click the "Shop Now" button below:
If you have any questions, feel free to ask them here, in a PM, or call our tech experts at 888.903.4348​
1 - 1 of 1 Posts
