1 - 20 of 30 Posts
Do you have to remove the half axle to replce the rear sprocket?
I tried but couldn't do it, would not like to remove the axle side of the procket.??
any of you replaced the rear sprocket thanks!
If have to will sell the 37 tooth rear spr.
hope not
yeah the front is easy but the rear I couldn't slide it out the axle.
you can change it but removing the bolts?/
sorry if i missed it but how many bolts do you have to remove?
4 bolts tires + 4 bolts sprockets+ loosen carrier to give slak to chain right.?
i think you got it there. but start with just loosing the carrier bearing nuts and loosening the chain.
The REAR stock sprocket wont come out the new one "sproket specialist" will go in though I think the stock needs bigger inside loops. the new one has them a bit bigger. I dont know but its not working. prbably will cut the rear sprocket, unless there is a easier way. wont take the axle off for sure.
Hope I like the set +1 in the rear for dunnning. if not will be forced to buy a new 36tooth
i will go mess with mine right now and see if i can figure out something for you... so did you get a 13T for the front and a 37T for the rear?
yeah i just took mine all apart and there is no way to remove that sprocket without alot of work or like you already suggested and i agree cut it off. yeah suzuki made it look like it would come right off but that is deffinitly not happening. let us know how it goes. good luck.
Glamis huh?...you better post it in the duning section or you will piss off the "Cowbell" god... :p
You could not get the rear sprocket off without cutting it ? I have switched from a 36 to a 38 and to a 37 and have not had to cut one yet it was a little bit of a pain but it came off just loosen chain pull wheel remove sprocket bolts give it a quarter turn push forward go over the sprocket flange 10 and 7 pull back and off at at 2 and 5.
Sounds easy enough...
Any questions?...Class dismissed :p
can anyone say? this thread soon to be hijacked!!! total drive from neah bay to glamis 24hrs 59min 1498.46 miles i believe thats without anystops :D .... i am willing to try it out if the schedule permits oh n if anyone who shows up promises not to laugh at the SSII's :lol: never been that far south so i'd love to go.
We will try to keep the mockery to a low roar... :p
Im in and and I will stay on my bike this time.
1 - 20 of 30 Posts
