Can anyone advise on the base setting (turns out) for the idle air screw on an 06 - i'm unable to find it in the manual or with my preliminary web searches. Also, would a cherry bomb require adjusting the screw from the base setting?
Thanks all.
nope, the CB would not require you to adjust it. If your talking about the High Idle or fast idle, a lot of us just blocked it off. search for fast idle block off
Thanks - just to confirm we're talking about the same thing - it's a large brass flat head screw on the tps side of the throttle body?
