M-XQuad-
Dude are you drinkin to much of that Hennesey, roll bars c-mon!!! Were not in sprint cars here. how do you have an inch of ground clearance in the back ? skid plate? and up front 2.5" what the?? 50" wide maybe a little wide I mean you don't want to wide sometimes ,cause' it will take weight off of the tires and traction might suffer. Think of it as P.S.I.(pounds per square inch) your trying to get the studs pushed into the ice. The harder the ice the more weight you would want on your tire. If you go to wide then you don't have the leverage on that tire to force the studs in the ice, and that goes for tire pressure also. Hard ice= high pressure, soft ice =low pressure. High pressure makes the tire bulge in the middle a bit and puts less studs on the ice which gives you more pounds on those studs and they can dig in better. To many studs on the hard ice will make it seem like it's skating or slipping alot, usually. Imagine studded tires on concrete it would spin alot correct? Soft ice you usually want more studs on the ice= lower pressure to flatten out the tire surface. Not saying what I run for pressures but, this is the way I have always thought about it, and well not to brag but, the results have spoken for themself.
