1 - 9 of 9 Posts
and the vin number is located on the plate that is welded to the frame down by the gear shifter.
frame is worn that bad? More like ground down. If you can't read the stamped plate something was messed with.
O9 has a different frame then all other years easiest way to tell is the rear brake light switch is tucked under the quad. Also the color combo yellow/blue red/black black/gold
1 - 9 of 9 Posts
