Well, we have a new one that should be here anytime this week. Hopefully soon, even though I wont be able to race it b/c of freakin football. o well. Ive been thinking of the mods i wanna add, how do all of these sound so far?
DASA Full Exhaust, (black can, with ceramic header) - need opinon on a heatshield to use with it
Cherry Bomb w/ lid removed
Pro Taper Handlebars
Spyder Grips
Non-Beadlock front Hipers with Kenda Klaws
Dual Beadlock rear Hipers with black rings with stock tires
Rath Gloss Black Pro Pegs
Pro Armor Pro MX Bumper. (black)
Either Rath or Pro Armor grab bar. (black)
Pro Armor, or Pro Design kill switch. (which do you reccomend?)
Powermadd's
ASV C/5 series Pro Model Clutch Lever-Anodized Blue . (had this on my 330ex and transferring it over, these things are awesome!)
Dirtbike killswitch as starter
Im thinking One Industries Graphics. But will take any input. (This is a YELLOW LT-R By the way, yes, YELLOW) go ahead and critsize
And custom number plates. Where do you reccomend I get them?
Plus, will the steering stabalizer, (Gibson 7 way adjustable/rebuildable) fit on my LT-R? It is for a 400ex/250R. I plan on buying a Precision down the road, but will use this if it works until then.
Thats all for now, tell me what you guys think, and Let me know if there is anything else you think i should look into.
**Also, on the Hipers, can you tell me what you guys used to mount them, like what all did you use under the nuts? I will flip them so the beveled edge is outward, but I still stripped off some of the material on my Bajas on my 300, and would rather not do this on the Hipers. So if you can tell me waht you guys used to mount them, that would be awesome and greatly appreciated!**
you talkin about a PIM or FIMAK? I think we are gonna get a PIM, but im not sure when. Which would I need first the FIMAK or PIM?
thanks, I'll be sure to look into that. What airfilter should I get? Im thinkin UNI or Twinair. Im stayin away from K&N though.
DASA exhaust has no mounting points for a heat shield.. you'd have to have all that fabbed up your own if that is what you want..
Stock lug nuts on the LTR cannot be flipped over due to the design...
it sounds like you have a good start....
i have a 450R heat sheild that I think i may put on, I just have to get a few new clamps. Im pretty sure that will work. And i just figured out I will have to get more nuts. Do I need to get flat washers, then lock washers? Will that work? or should I just get nuts only.
on my 250r when i got different wheels i flipped over the honda stock lugs and used flat washers. just check them often.. with hipers though i am not sure if they have a tapered hole or not... ask around if not call hiper and ask them.....
Discussion Starter · #10 ·
i guess i'll just have to see when they get here. Does anybody know where I can get the heat shield clamps for the stock 450R heatshield for cheap? I checked on bikebandit.com and it would be $20 some-odd for one freakin clamp
I just used reg nuts w/ flat washers underneth and a dab of loctite on all the studs.
Yeah madmatt has the simplest idea with the lugnut situation. I would get some different rear tires though. The stockers really aren't all that great. I use mine for practice tires. They like to spin A LOT!
Thats my .02 cents
later
Aaron
