I bought the FUELATV 1 1/8" bar clamps and a set of Pro Taper CR HI bends and they fit perfect. The Pro Taper universal mounts add some hight to the bars so I'm not positive what bend you would need. My cables are not stretched at all so I'm sure you could get away the the CR HI and the universal clamps. I'm sure someone else will chime in and give you a better answer.Im getting some 1 1/8" Pro Tapers and Im wondering what the highest bend of bars I can get without overstretching the cables. I will be using the Pro Taper universal mounts. Thank you very much.
Alright, Im thinking of going with the Pro Taper CR Medieum bend. This will end up being about 1/4" higher then your setup. There is enough slack in the cables for that extra 1/4" right?I bought the FUELATV 1 1/8" bar clamps and a set of Pro Taper CR HI bends and they fit perfect. The Pro Taper universal mounts add some hight to the bars so I'm not positive what bend you would need. My cables are not stretched at all so I'm sure you could get away the the CR HI and the universal clamps. I'm sure someone else will chime in and give you a better answer.
