1 - 14 of 14 Posts
Thanks for posting this. I just picked up my PIM as well. What becomes of the Cherry Bomb with the installation of PIM? Do we keep it installed or remove it? I would figure it would be removed but they offer the CB with their package so I guess it must still serve a purpose.
I think we all ought to grab our torches & pitchforks and go burn them at the stake until they tell us the truth! :angry:
Are ya WITH ME???? :D
The pim replaces the CRBM!
Installation took about an hour because I had never taken off the plastics. Plastics came off easily enough but they are a BITCH to get ligned back up.
Anyway the PIM is top notch as far as manufacturing goes. Really quality workmanship in all the connectors and wires. Instructions are excellent also. The only negative thing I have to say about it is the method they use to attach the PIM to the PIM mounting bracket. It's actually a velcro attachment. They could have definately come up with a better mounting system.
As far as performance goes the first thing I did was polish the header and rub it down with alcohol. I took it for a few spins down a nearby dirt road. My SOTPD (Seat of the Pants Dyno) tells me that there is DEFINATELY a BIGGER hit throughout the RPM range. Could it be wishful thinking? I'm not sure but right now I'm convinced it's there. Also no hint of the header turning purple so far. If it doesn't rain tomorrow I'm going riding and I'll see if it turns purple.
Al,
Thanks for the info! I wonder why they include the Cherrybomb on the parts list of the combo kit... I figured the PIM replaced the CB but was confused when I saw it on the combo list. By the way, I am praying for a lack of rain for you so you can put it to the test.
Al,
Unfortunately It's raining like cats and dogs today so it looks lilke no riding. You're right it is sort of mis-leading to show the combo kit with the CRBM because when you install the PIM there's absolutely no place to plug it in as the PIM plugs in where you unplug the CRBM and the instructions state clearly that the PIM replaces the CRBM.
Unfortunately Yoshi is the WORST company I've ever dealt with when it comes to getting consistant information. I specifically asked them a few months ago if the PIM replaced the CRBM and they stated that it stayed connected when you install the PIM. They definately need to sit everyone down in 1 room at the same time and explain how things work so customers get the correct/same information when they call and ask questions.
I wonder if there is a map for the 'bomb' to look at so as to compare the fueling between it and the next step up of using the PIM ?
Discussion Starter · #10 ·
I already have a call into Yoshi asking that very question. I want to see the maps sheets for the 2 maps that are already in the ECU.
Then we could see if there is really any need to invest in a PIM when the bomb could probably do ($39)
From what I read you use the bomb for a slip on and the PIM for a full exhaust and then add a FIMAK for full out mods ? (basically)
I just got back from a vacation in Cozumel mexico and had a PIM waiting for me. Now, if you dont know, Valium is available across the counter there, as well as other prescription pills. I snuck a few through customs, along with a couple REAL Cuban cigars (the best you will ever experience) and the instructions for the PIM are so easy to follow that I could install the whole thing after taking 4 Valuim. I do not condone this terribly irresponsible action to anyone else, I just wanted to test myself in an incapacitated state to find my true mechanical skills. Oh yeah, DO NOT try filling your gas tank with VP110 while seeing double from illegal pills and smoking cuban cigars, its can get ugly real fast!!!
Bar...you should really avoid that "Hippy Lettuce" :p
1 - 14 of 14 Posts
