1 - 9 of 9 Posts
Did you get ATV bend bars? With the universal big bar clamps you will gain something likr 3/4" height over the stock clamps. Then when you add ATV bend bars you have a combo that is too tall. Universal clamps work VERY well with cr high bend bars or some similar dirtbike bend.
A wise man indeed...Fuel's stuff ALWAYS goes together just perfect... :D
I used MX bars by Pro-Taper (henny reed bend) and they worked fine for me
Was that with the Big Bar clamps that raise the hight 3/4"?
well i bought new pro taper bars and with the oversized bar clamps and the cable for starting it with the clutch in is too short and the brake cable is short cables aren't long enough what can i do?
What bend of bars did you get?
I just got some Pro Taper YZ High bend bars with the universal clamps and it comes out to be about 2mm taller then the stock bar configuration. So if someone is looking for some 1 1/8" bars but wanna be about the same height as stock get the YZ high bends from pro taper.
1 - 9 of 9 Posts
