They are Black Powder coat. The stock wheels are very good for a couple of reasons
1. you can usually get them cheap.
2. rolled outer lip. IMO stronger then a Standard Red label wheel
3. the off set is right. When you go to a douglas you have to get 3 in 2 out off set. this 2 out 3 in off set will give you more feedback as the off set is not correct. In order to get a 4 in 1 out off set you have to get pretty exspensive wheels.
4. not too heavy.
So untill i can afford somemore OMF scalloped beadlocks or Hypers i will be on stock wheels. I mainly ride in the sand so the will be fine for me.
