Hey all my ltr has been acting up for about a month now and I’ve been trying to figure out what’s wrong with but I’m stuck
Issue: bike will start and run for id say 5-10 minutes then just die and throw fuel pump control system malfunction code, so I looked in the manual and it said check Ecu, Ecu seemed good so then it said replace fp( Fuel pump) relay, did that same thing still happens, I can turn the key on and off again or mess with/tug the wires in the front of the quad and it will start and run for a little bit but cut off again and throw the same code
Any ideas lmk, things to check etc
