Would you mind if I asked what type of application you'd be using the floats for? Just out of curiousity...
Really, the floats are great shocks for drag racing quads; the extremely low weight is great and they can be adjusted well enough to meet the needs of most draggers.
Once it comes to a motocross quad however, the decreased weight isn't enough to off-set the less than satisfying damping conditions. The stock shocks perform much better than a pair of regular floats would on an LTR. Now, I'm not going to say you have to go buy a pair of Evol's to ride competitively if you're still looking to cut the weight; but I'd highly recommend it. Honestly, the better performance from stock LTR shocks would perform better on a motocross track than cutting 5lbs; plus then you don't have to spend a dime.
Either way, I'm not going to talk you out of anything I just don't want to see you be unsatisfied with a new purchase.
To answer your question, I'm not sure of anyone directly that sells the regular floats. However, I know that
Cernics Racing is a Fox Suspension dealer and would be able to answer your question in a respectable time if you contacted them.
