Hey Guys i have a 08 ltr 450 and noticed on my last trip that my fan wasnt turning on. It was a couple hour trip with a couple 10 min stops here and there with 80 degree weather. Is this normal? if not where do i begin on trying to fix the issue? im running engine ice if that makes a difference. I have a open air box with a K&N filter and full Yoshi exhaust system.
Mine usually only comes on when idling for a long period of time.
Check your fan relay, just had the same problem on my 09 and it was the relay, check for corrosion, you can "hard wire" it so the fan stays on all the time until you get a new one, I was able to take a couple fuses and put them in place of the relay and tape it up. The fan will stay on all the time, even with the key off so I took the side plastic off so I could pop out the fan fuse and it would turn off.
