During a race last week I landed real hard (over shot a double & flat landed) the bike stall instantly & did not want to start again! I finally got it started and now it runs rough. It pops and farts won't hold an idol. I can forget about hole shots, it just stalls. It also makes a grinding sound enen in neutral with the clutch pulled in. I changed the oil right away, no shavings. checked valve clearance it's within spec, pulled all wire plugs and cleaned with contact cleaner.
I have rode lightelly around the yard for about 2 hours and checked oil again, still clean!?!?!? I don't want the dealer to work on it, they are backed up like 5 weeks.
I landed hard enough to crack my frame in 3 places on the FRONT END!!!(more on this with pics in another topic to follow)
I'm wondering if it isn't in the overturn kill switch,or the EFI/ throttle body, the bike took a hard shock on this landing(falling 8 feet onto flat ground in 3rd gear 1/2 throttle) as did I. Any direction on approaching this issue would be greatley appreciated.
