Hello guys, i buy a very very clean ltr. All looks and works great. Start at first button push, have enaught power but I have only a small “problem”. From what i know from the seller the piston was changed or the motor was rebuild since 8-10h ago. I repet the motor run perfectly , nice sound , perfect start-up.
when I leave it on the slope it starts to slide slightly by little as if it loses and has very weak compression. Also if i let it in 1st gear and i force it to slide the vehicle i could move it 10cm and slide the wheels. can it be out of the transmision? is it normal to do so?i need to test the compression to be sure, how many psi need to have?
Compression should be over 100psi.
