1 - 9 of 9 Posts
I have a 06 ltr and I want to get a slip on exhaust. I'm looking at the hmf exhaust. I currently have a cherry bomb, no baffle on the exhaust, and the airbox lid off. I would like to know if I need to get a pc3 or anything like that if I get the exhaust.
i ran a cherry bomb with modded air box some head work cams and a full exhaust no problem and i know some people run just a cherry bomb with a high compression piston but i wouldnt do it.
if you get an intake or do a big bore defiantly get a fuel controller.
if you think its running lean pull the plug and check the color.
^^ Incorrect. If you do cams, you then should have a controller.
I ran mine with hot cams intake cam and 08 exhaust cam and I was fine with just a cherry bomb. I checked the plug and it was good I also had a full exhaust and modified Intake.
1 - 9 of 9 Posts
