261 - 280 of 283 Posts
I need a pciii map, anything close
07 ltr
Cherry bomb
Cylinder works 474 kit
Stage 3 Williams porting
Exhaust- Dr.d header stock muffler with baffle removed
Intake- uni with lid removed
Cams- hot cam intake
Valves- +1 titanium intake and exhaust
Fuel- 91 octane
Elevation- sea level
Need help with a fuel map for a PCV with the following:
Exhaust: Full Dasa classic
Intake: K&N
Airbox: No Lid
Piston (Compression): Stock
Cams: Stock
Valves: Stock
Fuel: 91
Elevation: 1500 to 2000
Approximate Temp: 70 to 90
Thanks for any help!
Does anyone have a map for this:
Exhaust: Yoshi RS5
Intake: Pro Flow
Airbox: Custom Cut
Piston (Compression): Je 13.5:1
Cams: Stock Intake, Stock Exhaust
Valves: Stock
Fuel: (110)
Elevation: 700
Hi
I need the best map for
Exhaust:DASA Full
Intake:K&N
Airbox:Yes
Piston (Compression):11.7:1 98MM
Crank +3mm Stroker
Cams:S1 Intake & S1 Exaust
Valves:None
Fuel:95
A/F ratio:None
Elevation:700
Approximate Temp:90
Does anyone have a map for a stock motor with dasa exhaust, hot cams stage 1 intake and exhaust and a pro flow k and n filter kit with no air box lid with a pc3
I need a map of anyone has something close for a pcv on an 07
Exhaust: full rossier
Intake: stock cut box no lid
Cams: hot cams intake and exhaust
Piston: 100mm 12.8
Stroke: stock
Cherry bomb
Fuel: 100 octane
Elevation: 4500ft
Anyone that could help would be appreciated
Need map for PC3
MODS:
Yoshi full exhaust
pro flo intake
ported head by tyler post
web cams IN and Ext
Cherry bomb
wiseco stock comp.
help need fuel map
i need a pc5 fuel map for 07 ltr 450 with same or similar mods.
Mods:
kms 535cc big bore kit 13.5 ratio "will be running 104 race gas"
kms v4 cnc p&p
+2 intake +2 valve
46mm tb bored
hinson billet clutch kit
x3/x4 megacycle cams
full dasa exhaust
fuel atv intake
cherry bomb
Help powercommander pc5!!!
hi guys I would like to know if anyone can help me ... I have a 450 Ltr with Yoshimura RS-5 exhaust air filter pro desing, high compression piston Wössner , hot cam stage 1h and I acquired a power commander PC5 and can not find my size map on the web ! someone could give me some that suits my preparation ? Thank you
Pc5 tune
07 ltr 450
Hot cams
Baffle out
Fci intake
Cherry bomb
Tried some different tunes but it still seems to bog. Does anybody have a map? Thanks!
Hey guys new to the forum here my very first post actually but I just purchased a PCV for my 2006 ltr and I am in need of a map. Motor is stock, cams are stock, lrd full exhaust, cherry bomb, stock air box with k&n filter with no lid, elevation of 2000
well since I cant get a map to compare with mine, I will post my map created with my auto tune and maybe someone an tell me if the map looks ok or dangerous etc. I know that all bikes are slightly different, but I'm new to this whole tuning thing. So mods on the bike are:
2008 ltr
Full yosh exhaust system
Fuel atv intake
Hotcam intake cam
Stock exhaust cam
PCV
auto tune AFR set to 13.5 across the board except column 0.
Rest of motor is stock.
0 0 0 0 0 0 0 0 0 -1
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
-13 0 0 0 0 0 0 0 0 0
-13 0 0 0 0 0 0 0 0 8
-13 -25 -4 -36 -35 -36 -36 -30 -28 -24
-13 -31 -18 -19 -9 -36 -36 -16 -36 -48
-13 -18 -20 -12 -1 0 0 0 0 -51
0 -23 -22 -11 -1 6 2 0 0 -28
0 -18 -22 -14 -2 5 0 0 0 -13
0 -22 -17 -14 -4 -1 0 -1 0 -21
0 -32 -16 -14 -4 -3 7 0 0 -11
5 -30 -13 -12 -14 -7 7 2 4 -13
5 -33 -20 -17 -12 -17 0 4 1 -14
5 -17 -36 -16 -18 -14 7 6 6 -21
5 -5 -29 -18 -13 -15 -4 5 -3 -15
5 0 -30 -27 -17 -25 -9 6 0 -18
5 1 -30 -24 -17 -17 -12 5 2 -21
5 -4 -16 -20 -14 -17 -19 1 5 -19
5 -2 -5 -19 -14 -14 -23 -5 -2 -21
5 -1 -6 -22 -18 -16 -27 -13 -1 -18
5 -2 -4 -10 -22 -21 -24 -18 1 -21
5 0 -1 -1 -9 -22 -26 -22 -7 -21
5 -2 -1 -1 -1 -15 -23 -22 -9 -19
5 0 0 -2 -1 -8 -20 -19 -11 -11
5 0 0 0 0 -7 -16 -16 -6 -8
5 0 0 0 0 -2 -9 -17 -4 -4
5 0 0 0 0 -2 -11 -13 -8 -7
5 0 0 0 0 -1 -15 -12 -8 -4
5 0 0 0 -1 -1 -12 -14 -5 -3
5 0 0 0 0 2 -12 -16 -5 -6
5 0 0 0 0 2 -11 -19 -5 -5
5 0 0 0 0 2 -5 -13 -4 -4
5 0 0 0 0 2 3 -7 -5 -1
5 0 0 0 0 2 3 -4 -3 -2
5 0 0 0 0 2 3 2 -2 -5
5 0 0 0 0 2 3 2 -1 -2
5 0 0 0 0 0 0 0 -1 0
5 0 0 0 0 0 0 0 0 0
5 0 0 0 0 0 0 0 0 0
5 0 0 0 0 0 0 0 0 0
5 0 0 0 0 0 0 0 0 0
5 -3 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 -3 -5 -1 -1 -1 0 0 0 0
Any advice would be greatly appreciated. thanks.
Help! I need a tune. Mods below-
Stock Bore and Stroke
Stock Compression
No Head work
Yoshi Full exhaust
Velocity Intake with open lid
PC3
Hotcams intake and exhaust cams
Inline fuel filter.
Sent from my iPhone using Tapatalk
Pc3 map hot cam yoshi
Need a map for this setup
Stock Compression
No Head work
Yoshi Full exhaust
PC3
Inline fuel filter.
Between 900-1500 ft
did you ever get a map for this setup? i have similar but with full Yoshi rs5 elevation 2500-4000 elevation and im looking for a map. i believe a map would work
pc5 maps
Would anybody have a map that's close to my mods be willing to share it with me? Williams Performance stage 3 race port head with +1 intake and exhaust valves, big bore kit with 13:9 comp piston and custom grind webb cams. Full sparks big core exhaust and pro flo intake kit with K&N.
Here is a map I build for my 06 LTR496 Big Bore
PCV, Auto tune and POD300
935FT Elevation and 70's
Target AFR 12.8 with engine Temp around 200 Degrees
Piston - JE 98mm 12.8:1 (91 Pump Gas 100%)
Crank - Hot Rod Stoker
Inline filter (stock removed)
Stock Injector
Hot Cam intake Cam / Stock Exhaust
Uni Filter
Stock Intake
Stock Exhaust with modified stock plug (restrictor removed and re welded)
Ported Head
Pro-X Steel valves (Stock Sizes)
13/38 gears with 20" Tires
Set Accelerator Pump for sharp throttle hits.
A little cold blooded to start (cold Start)
All throttle positions were screw set to maintain accuracy
All Tuning done on pavement
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
10 0 0 0 0 0 0 0 0 0
10 -3 1 0 0 0 0 0 0 0
19 1 29 4 8 9 9 9 9 9
11 23 5 -2 0 -4 -2 0 9 9
9 9 -11 -3 -6 -6 -6 -3 9 9
9 1 -7 -7 -10 -4 -6 -4 -13 -3
9 -7 3 1 -5 6 -4 -7 -7 -12
9 -14 0 -4 -3 9 1 -3 -13 -13
10 -12 3 2 -1 5 4 4 -2 0
10 -9 2 -3 -7 2 6 -2 2 -2
10 -15 -2 -2 -9 -3 3 7 6 -2
10 -7 -9 4 -10 -2 6 11 4 0
10 -2 -15 3 -7 -1 4 7 6 -4
10 -2 -12 8 -1 1 4 10 2 -2
10 0 -9 4 -1 -1 3 10 11 6
10 1 -11 4 0 -2 3 9 5 4
10 0 -11 6 2 -2 1 11 9 8
10 0 -14 1 1 -1 2 8 10 6
10 0 -9 -4 -1 1 4 9 10 11
10 0 -3 -9 0 4 5 6 12 12
10 0 1 -13 0 4 7 9 10 12
10 0 0 -9 3 7 7 9 12 16
10 0 0 -14 6 12 9 7 16 12
10 0 0 -11 4 12 3 11 12 18
10 0 0 -9 8 12 1 11 16 20
10 0 0 -4 7 16 -1 12 18 27
10 0 0 3 7 12 -1 12 23 27
10 0 0 9 7 18 5 12 18 20
10 0 0 9 9 12 11 11 12 12
10 0 0 9 11 12 12 12 12 12
10 0 0 9 12 16 12 12 12 10
10 0 0 9 11 12 16 9 10 11
10 0 0 9 11 12 19 17 12 12
10 0 0 9 11 12 16 16 10 12
10 0 0 9 10 12 17 17 10 12
10 0 0 9 10 11 12 16 21 11
10 0 0 9 9 9 20 12 18 11
10 0 0 0 0 0 0 0 6 5
10 0 0 0 0 0 0 4 18 8
2007 LTR 450
Exhaust: Stock with baffle removed
Intake: Uni Filter
Airbox: Stock with lid removed
Piston (Compression): Wossner 11.7:1
Cams: Hot Cam Stage 1 intake cam / Stock 2008 exhaust cam
Valves: Stock
Head: Port and Polished
Fuel: 91 pump gas
Elevation: 59' - 69'
Approximate Temp: 70 to 95 (Its Louisiana)
Cherry Bomb
Looking for a map for my setup, I am getting a slight bog on the low end I think due to it not being tuned correctly.
Mods:
496big bore w/hotrods bottom end
Yoshiumra rs-x exhaust
No Air Box
K&N Filter
PC3usb and CherryBomb
