241 - 260 of 283 Posts
need map, help please
running a 2006 LTR 450. stock motor, 14/36 spocket, yosh chip, full yosh rs5 aftermarket intake, k&n filter, no lid, auto tune, power com 5, looking for maps that work well with these mods
I need a map for my PC3 on my 06
it has stock airbox with k&n with lid removed
hotcams stg 1 intake and exhaust
steel valves
head is stock
12.8:1 JE piston std bore
hotrods crank "idk whether its stroker or not"
yosh cherry bomb
pro circuit pipe
Please help
hey guys i have a 06 ltr with a athena 490 big bore kit, pump gas, yoshimura slip on with quiet core in, ps3 lid off with uni filter. can someone please help
Guys I need help? I have a 2006 ltr 450, when I bought it, the air box lid was off, some kinda yoshimura plug in up front, and motoworks pipe and motoworks fmi, the bike worked good and I fucked around with my settings and don't know what it was originally, I know there's 5 diff settings and what not and I know what the settings do but can someone give me a baseline of where to start, ffs
help
Any one know what map I could use on my quad I have a full rs5 yoshimura exhaust, cherry bomb air box led removed [email protected] air filter, pc3, stage 1 hotcams,+3 hotrods stroker crankshaft and a 11.7:1 piston polished and aluminum head
power commander help??
Ok you guys need to go back to the main source.... this includes all of you asking the same ?? But w/ diff names?? Goto to pwr commanders website or call there tech service and you can dwn load theremanuals.
Any body have a map for-
07 ltr 450
496 big bore stroker
full dasa exhaust
Race valve job
Stock valves
pc3
cherry bomb
pro design intake
Edited: has 12.5-1 compression piston
I just read through 10 pages and didn't see anything about my set up.
07
Full dasa exhaust
Fuelatv intake
Pc3
Cherry bomb.
Everything else is stock. Can someone point me in the right direction?
wondering if anyone has a pcv map for
full yosh rs5
fuel intake
everything else stock
2500ft and 1000ft
thanks!
i couldnt get big robs 1st map to open
Anyone have a PCV map for this setup? Also does elevation play a huge role? i found a map with this setup but for 1500 elevation. I usually ride at around 9000 ft
Exhaust: Dasa full exhaust
Intake: fuel
Airbox: none
Piston (Compression): stock
Cams: stock
Valves: stock
Fuel: 91
Elevation: anywhere from 6500 to 9500
Approximate Temp: 65-75
Here's what I need a map for 13.1 cp piston stock bore. Port and polished head, web cam intake hot cam exhaust, +1 exhaust valves. Bored 46mm throttle body. Air intake. Full drag pipe running on 110 or mr12. PCv on an 06. Would like to get something similar until I can get it dynoed.
Exhaust: Curtis Sparks Full Big Core
Intake: Stock with lid
Compression: 13:1
Fuel: VP VPR
Mild P&P on head
Hotcams intake cam
Does anyone have a map for this? Is the regular sparks w/stock intake map good enough?
06
2 brothers head pipe and a street bike muffler
Ported and polished head stock valves
Athena 490 kit
Hot cams
K&n filter not lid
Mostly as the coast so sea level up to 1000 ft?
I have a PCV with an auto tune but wanna see if a built map will make it perform better. Thanks guys
Anyone have a map for me?
Exhaust: Hmf slip on
Intake: k&n pro flow
Airbox: stock
Piston (Compression): 474 bb
Cams: ported head
Valves: stock
Fuel: 93
Elevation: 700 above
Approximate Temp: 65-80
Looking for a bolt on map to run a base test on my bike.
Sea level
full dasa exhaust
fuelatv intake
pc3 programmer
It came with a tune on it for a trinity 493 big bore kit. but i have a stock jug and that just doesnt seem right to me. the tune on the bike now is.
trinity bigbore 493
trinity head port
dasa exhaust
JE 13:1 piston
Hotcam intake cam
Fuelatv intake
dynojet Rev ext
With this tune my friends stock ltr beat me in a drag.
Can someone plz help out thanks:beerchug:
Looking for a map with the following - 07 LTR450
Exhaust: Full Dasa exhaust.
Intake: K&N intake
Airbox: Lid removed
Cams: Intake cam
Valves: stock
Fuel: 91 octane
A/F ratio: stock
Elevation: sea level
Approximate Temp:75
also have cherry bomb, swirl filter delete, pc3
