[attachmentid=36][attachmentid=37][attachmentid=38]this is a easy and quick free cosmetic mod for your quad just take the 4 screw out from behind hte headlight assembly to separate teh plastic pice from the light use then tuck it up under the hood and use some electrical tape to hold it in place and to see where u want it to be mounted now take 2 of the screw you took out have a drill use a bit smaller then the screw drill through both pieces now insert both screws and there have have it easy free hood scoop and to keep some debris from coming in underneath u could also hold a piece of mesh using the orginal light mounting holes as well for a clean look heres mine pics
