Just wanted to give you guys a look on what I had to do to the crf head to get the crf 250r angled boot onto the head to allow the carb to clear the rear shock mount.
The head is rough right now as I'm still tweaking it and this is probably the 6th time I'm tweaking a few things in the intake track. (I still need to sand roll the intake tract smooth it out etc)
You'll notice that you have to offset the head opening as the crf 250 boot makes the carb kick up and on an angle. If not you will likely have about an 1/8" or so of the head impeding air flow.
I would love to be able to get the Trx 450 head on the atv however I do not believe it will fit as it has a more centered intake track and I have to have the angle from the crf head to make the rear shock mount work without hitting the carb on it.
This motor runs very well and will pull my mildly built Ltr without a problem.
I use 14/38 gearing on the crf motor (pretty tall if you ever have ridden a crf motor the 1-2 gears are very long) and 13/38 on the Ltr
Pictures are below.
Pictures are below.
