1 - 9 of 9 Posts
Can someone explain to me if the geometry of the LTR450 differs from from the years 06 to when they got discontinued? and if so, how? and is it a huge difference? or are the frame's simply all the same from the 2006 model onward?
Cheers guys
believe the only change was slightly softer suspension in 08,09 and alluminum subframe in 09
09 has some change to front spindles. But not sure what
The '09 frame is the most different as suzuki changed the rear brake lever. Other than that the frames are pretty much all the same.
no it doesnt ^
frescasipper
Maybe someone replaced his with a 08+ unit
i must of got the shaft then because my 08 is definatly steel too. its the 09+ :fing02:
1 - 9 of 9 Posts
