All you need to do is loosen the 4 12mm bolts on the back of your swingarm and then slide a screwdriver threw the rear sprocket into the carrier hole.. then pull your bike backwars and it will pull the carrier tighter.. similar to hondas set upWell I lost my owners manual and my chain is pretty loose, so I need to know how to tighten it. Any help would be great and pictures would be awesome too. Thanks a lot.
